therion
Yup, seems to be exactly the same as the one on my 1993 Jag. The transmission in this 97' shifts alittle rougher from 1st to 2nd than my xj40. But all the other gears are smooth as butter. I will let you know if the slight jitter will cure once i change most of the fluid out (it will be today). The engines in these cars are truely marvelous, I love the huge torque at such low rpms with thse 4.0L I-6's. My 2003 Audi A4 1.8T is quick too but only once the turbo spools up, with the Jag it's instant power and even at high rpms makes little noise, something that can't be said about a 4 cylinder. Cheersquote:
Originally posted by Win:
OK, I thought I remembered you from Jag-Lovers.
I thought the AJ16 had the exhaust valve seals installed from the factory; even on the AJ6's I think that is a pot luck issue - neither of my AJ6 engines puff even after sitting for weeks or monthes in the case of the wife's Vanden Plas.
Does the 1997 still use the ZF transmission? I drain the pans on my Jags (and other cars) every 3K when I change the oil, so, yes, I think that is a good practice that will yield practically unlimited tranny life in the case of the ZF. The ZF4HP22 in my 89 Xj6 still shifts like new after 225K miles; I do worry about the 4L80E in my Xj12 not being nearly as long lived as the ZF's.
As long as you have the factory installed oil cooler, I would leave the Jag alone and just change the oil and tranny (and other) fluids regularly.
Good luck.
