Originally Posted By: GMBoy
After reading all the posts, let me just say this:
1.) Skip the 4.8 if at all possible. Not that it's a bad engine, it's a good engine. The reason is simple - the 5.3 delivers plenty more power and torque and gets BETTER fuel economy. Yes, that is true. Not a lot better, but better and with more power is a winning hand.
2.) Ignore the AFM comments, the system is reliable and works seamlessly..you don't even know its working unless you look at the dash display. This is not the same system as the old 1981 era Cadil1ac V8-6-4.
I had one of the new body style 2007 Silverado's(GMT900). It was a 1500 Extended Cab 4WD w/ 5.3L( w/ AFM ). It was also a 1LT with the Z71 package. It was a very nice truck. No mechanical issues and the AFM was seamless unlike MDS in my Dodge Ram. You absolutely could not tell when it was on/off unless you had the DIC on to tell you. The only thing I did not like was the seat fabric as it was a lint magnet. You couldn't clean it so with such dark material they always looked dirty and my vehicles are kept spotless. Seat covers solved it. If the only gripe you have is seat material I would say that is a good indication it is a good vehicle.
I also agree wholeheartedly that it makes little sense to get a 4.8L. MPG is as good or better with the 5.3L and the more power in a full sized truck the better. As said ^^^ it isn't that the 4.8L is a bad motor or anything but the 5.3L is more appropriate for a big heavy truck.
If the OP wanted a regular cab, 2WD, model and he never pulled or hauled anything the 4.8L would be ok. However, he wants either an EC or a CC and he will use the truck like a truck at times. He also wants 4WD if possible. 5.3L is the only option of the 2 motors IMO.
To the OP;
Crew Cabs Pro's...
1 - You have independant access to the rear seat. No need to open the front door.
2 - More room in the rear if you will ever have passengers.
Crew Cab Con's...
1 - much higher cost
2 - loss of bed space
I have had Quad Cab( Crew Cab )Rams and Extended Cab Silverados and both are ok. I prefer a true 4 door but the Silverados with the Ext Cab did the job just fine. I really liked the NBS 2007 Silverado with the way GM redesigned the doors to allow them to open fully over to the bed giving you some real access to the rear seat area. On my 05 Silverado the rear doors only open part way and you can get trapped between the doors if parked next to a vehicle or building.
I also liked how they made the rear windows operate the same as regular windows. No more camper type pop out windows like my 05 EC Silverado had. You had to open the rear door to open those windows. On the new model you use a switch like a regular window. BIG improvement.
The NBS 2007+ GM Trucks(GMT900's)are really nice. I think you will like it a lot. I just truly believe it is worth the extra $$$ to get one with a 5.3L. Do a compromise. Spend a little more for the 5.3L but save some $$$ by getting an Extended Cab instead of the Crew Cab.
Good luck.
My 2007...
Excellent writeup, I agree 100%. Nice truck, too. That color is nice and you don't see many at all.
Actually, that color is way too popular around here. I thought for sure I would be different than most ordering it but turns out here it is one of the most popular colors.
Now I drive a Silver Dodge Ram. Has to be the most popular color for the Ram next to Black. I hate looking like everyone else.
Couldn't pass up the deal I got on it though so color preference had to be set aside.
About a year after I got the 07 Silverado I was at the dealer and was looking at the new trucks as my truck was being serviced. Came across a very dark metalic maroon color that I absolutely loved. As I recall it was called dark chery metalic or something similar. I don't see it being offered anymore but man I wish that was offered when I got that Silverado. Hands down it would have been the color I ordered.
