Quote:
Nothing wrong with the filter. It was damage when it was cut open.
Interesting conclusion. Not sure how one would arrive at such based on the pics and information supplied. Considering the can was cut open at the base end highly unlikely it would have any effect on the dome end bypass shown. True, nothing wrong with the element itself, bypass not so much.
As for whether the defect had an effect on bypass psi, imo the psi is based the spring engagement of the four tabs on the spring end, not two of the four tabs. OP notes it works, stays closed and opens with pressure. Whether in operation mode that opening psi remained as spec'd, without testing, speculation. Either way in this case, in all likelihood little if any effect on function imo.
Thanks for c&p.
Thanks for c&p.
