I was going to go with '70s F-100/150 but front kingpins ruined that.
Juggled back and forth between 73+ Chevrolet C10 and 72+ Dodge D150. The C10 has a pad mount starter that is easier to replace than the Mopar gear reduction starter but the Dodge's control module and coil is easier to service than the HEI.
Originally Posted By: 84zmyfavorite
96 thru 2001 Jeep Cherokees for a fuel injected vehicle, cause I know em. Most any pre smog pick-up(1974?-earlier) for carburated vehicle.
I agree with the Jeep Cherokees I loved working on mine. Most Hondas are easier too.
Originally Posted By: hstuehmeyer2000
A V6 Mustang. It is 2WD RWD and has a V6 where a V8 would be. Lots of room to work.
That's true! I just did a tune up on a ladies 2004 V6 Mustang and it only took about an hour for plugs, wires and coil replacement. I threw in MAF and throttle body cleaning too. I was taking my time and explaing to her what I was doing too.
My 1982 Celica required a wrench and two screwdrivers plus feeler gage to adjust the valves, including removing air cleaner and valve cover. I changed the oil pan gasket needlessly (front crank seal) book said pull one motor mount bolt, jack engine and put a 2x4 to block it. Pan weaseled out.
One of the few cars I ever worked on that I got the feeling the engineers put in lots of energy into making it easy to service. Lots of fasteners the same size used too.
Last generation carbed engines were kind of complicated though.
