Originally Posted By: SteveSRT8
Originally Posted By: skyactiv
I've read it's really common for the Focus RS to blow the head gasket.
Especially when it's really a 2.3 EB Mustang head gasket! There are subtle differences in cooling passages from the 2.3 in the Focus vs. the 2.3 in the Mustang. This means when the head gasket is used on the wrong engine there are ports blocked that cause boiling that blows the gasket.
It's a classic case of poor quality control at the point of manufacture...
This. It's because one engine is transversely mounted and the other is longitudinally mounted. The coolant outlets are on opposite sides of the head so therefore the coolant flow needs to be routed differently from the block to ensure proper even cooling. Using the FWD or RWD gasket in the wrong app will overcool one end of the head and overheat the other end.
