If Delo will go 400,000 miles in a pick-up diesel, what engine mechanical features are different in a gas engine to prevent it from reaching the same milage?
Thanks,
Dale
Thanks,
Dale
The main reason is the diesel engine is designed for heavy duty use and to be run long hours. The other factors are significant but not overwhelming. EGT on a diesel will be lower, things being equal due to greater airflow through engine and more of the energy turned to power (less to heat).quote:
Originally posted by 1sttruck:
Malfunctioning injectors in an otherwise good diesel engine can result in very high exhaust gas temperatures, leading to holed pistons, burned valves, etc.
Fuel lubricity is a factor, but how big of one ? If it's the main reason that diesels last longer than gas engines then gas engines can never last as long as diesels (not) and turning a gas engine into a diesel will make it last as long as other diesels (not).
