Originally Posted By: joegreen
Thanks for the info on the atf. Ill run by my napa tomorrow and see whats up. As far as the dual feed mod you have convinced me not to do it. Also I am trying to do this rebuild on the cheap. Is it really necessary to rollerize the tail shaft?
It is not necessary if the locating tabs on the Case that locate the 3-tab selective washer are in good shape. Be sure to set the "Rear unit end-play" within factory specs.
