Originally Posted By: badtlc
Originally Posted By: panthermike
badtlc, didn't you mention before compression was improved on a 15K engine? I still wonder why the engine was down on compression after 15,000 miles.
Who said compression was down? Compression was well within factory specs. It just improved and stayed at the top end of factory specs. It was about a 2-3psi improvement in all cylinders.
I saw drastic compression improvement on a 96 cavalier 2.2L with about 90k on the Odometer and that cavalier had seen regular OCIs of 3k since new.
And of course, this led to improved MPGs in all 3 cars I have used it in and reduced idle fuel consumption.
It is obvious to me that ADMIN did, in fact, come in and delete the two pages forward this page in the thread.
badtlc reinforces information i too have heard and is possible, and i will try it in my car.
sprintman has offered nothing of significance and im happy his certain posts were removed. That sums up the missing pages.
Ad to the A-RX, I was saying that i will be double-dosing my car with SuperTech to get the benefits, and it makes NO difference to me if it makes the inside "Cleaner," More sealed and possible increased compression and cleaner rings, as ive heard of on at least two cars NOT from their site, is enough to make me plink down the $180 on the bottles my car needs for a double dose.
My Oil will likely look like MUD, making me fear for my HG's (Head Gasket) life.. though it passes its tests, ill have to re-do them, nervous until it passes the Pressure Test and "No Bubbles" test, new WP, then im fine.
A failing HG is really the only other thing (besides Sludge in a nasty amount) that can make Oil look that way. One or the other.
MUD, i say. MUD-looking Oil. Much like the pic on the other one, thick, gluggy-draining Oil.. WOW! Changing Filter, for SURE! Maybe even once more!
And No Mos2 until AFTER its done, it makes it run great. No MMO either, except in fuel. And Regane and ZMax in fuel.
