Anyone see a major conflict in this trailer
GON
$100 Site Donor 2024
Steilacoom, WA
Cam across this gooseneck trailer for sale in Fargo, ND. The price at $8900 seems more like pre VID pricing.
Going through the pictures- something sticks out to me- anyone else catch it?
Assuming 30% tongue weight - The trailer axles aren't rated high enough for the payload capacity + trailer. There is a 2800 pound shortfall.
24000 GVWR * .30 tongue weight = 7200 pounds on the gooseneck. Leaving 16,800 pounds carried by the axles. Axle combined rating is 14,000 pounds. Oops.
Bingo!
And that causes another effect. CDL. With a trailer GVWR of 24,000 LBS, the tow vehicle would need a GVWR of 2,000 LS or less. By having a posted GVWR of 24,000 LBS, this causes this trailer to require the operator to have a CDL license and follow CDL regulations. Yet, the trailers GVWR is likely 14,000 LBS. Huge secondary issue.
Only if hauling commercially. People hauling for personal use are fine.
I don't believe that is accurate. To the best of my recollection a CDL is required for any non RV combination of over 26,000 lbs.
This is why super duty pick ups have a true GVWR of well over 12,000 lbs, but are derated to under 10,000 lbs, to avoid gvwr issues.
Looking at the flow chart, it seems a private F350 “power unit” rated at 10,000 could tow a private trailer up to 21,000
I think a power unit at 10,000 lbs could tow a trailer with a GVWR rating of 16,000 LBS or less.
@GON, I think you should look more closely at the CDL requirements. For you own personal use, you shouldn't need any type of CDL.
Thanks, I do have a CDL A. Kind of a pain to maintain as it requires a physical every two years that needs to be submitted to the DMV.
Yeah, I had an F550 bucket truck that I bought from a buddy. I had to get commercial insurance and was supposed to stop at scales even though it was only for personal use. At least I didn’t need a CDL to drive it! The whole thing was a hassle and I sold it after a month.
The "occasional, recreational transportation of personal property for a non-business purpose" is exempt from Federal CDL rules regardless of weight. However, state laws may apply.
Seems you are correct-
1. Does the vehicle or vehicle combination have a GVWR, GVW, GCWR or GCW (whichever is greater) of 10,001 pounds or more?
If NO, then the HOS and CDL regulations DO NOT apply.
2. Does the vehicle or vehicle combination have a GVWR, GVW, GCWR or GCW (whichever is greater) of 10,001 pounds or more, but less than 26,001 pounds?
If YES, the individual MAY need an ELD to complete the RODS. However, a CDL is NOT required.
3. Does the vehicle or vehicle combination have a GVWR, GVW, GCWR or GCW (whichever is greater) of 26,001 pounds or more?
If YES, the driver MAY need an ELD to complete the RODS and a CDL MAY be required.
4. Is the vehicle being used for the occasional, recreational transportation of personal property for a non-business purpose, such as taking a personally owned animal, vehicle or other personal property to a show when the underlying business is unrelated?
If YES, the HOS regulations DO NOT apply. A CDL is NOT required unless the licensing state requires it. Note: Drivers must verify the licensing requirements in their home States.
You can tell GON-he doesn't see my posts......
As do I.
I haven't NEEDED it since I owned class 6-8 trucks, but it has come in handy in the hobby I pursued for many years. Took a break from for a few years, and may get back into.
  • Like
Reactions: GON
