I didnt like it when I first saw it, but its growing on me. Looks like something that would look natural in like...Fallout 3...Retro-futuristic.
The low headlights does help the blinding other vehicles thing, which is drawing attention lately.
idk I wouldnt buy one but I wouldnt complain if I was given one as a work vehicle.
Originally Posted by 02SE
Originally Posted by maxdustington
Originally Posted by SubieRubyRoo
6.0?? I knew you were taking advantage of Canada making weed legal. The 6.4 was a monster for Ford; never before or since have I ever seen an engine capable of 500rwhp from nothing but a tuner and high flow intake (Cummins may be close, but the transmissions have always been the weak link). Ford 6.7s are OK but have about zero usefulness to generate more power than stock, the turbo is sized almost exactly to the stock power output. However, give me a 2007 Super Duty any day over a newer body style- the front ends just look so much cleaner than 2008-newer (just like this awful-looking Chevy).
6.0s were OK, if you eliminate the VGT, EGR, and factory head bolts and head gaskets. Short blocks were typical International tough but it shouldn't take $5k in aftermarket parts to make the thing live when you've dropped $60k on a truck.
I was under the impression that the 6.0s are the best because they have the least amount of emissions and it just got progressively worse after that? I'm no expert. 10-4 on the old Super Duties, they are sweet. I remember them when they were new.
The 6.0 Powerstroke was the worst engine by far of any of them. In terms of Super Duty Diesel reliability of the last 20 years, the order from best to worst is 7.3, 6.7, 6.4, 6.0. Some have been lucky with a 6.0 that was kept stock. Usually they need to be 'bulletproofed' (you can research all that entails) before they can be considered reliable.
I'd disagree. The 6.4 is definetly worse. The DPF and the using of the back two cylinders to spray flames through the turbo to clean said DPF eventually results in their untimely demise with no good core to repair from. The 6.0 shouldve had OAT from the getgo, would have prevented problems with silicate dropout from the G05 causing EGR and oil cooler failures. That was a significant amount of the issues with it.
