- Joined
- Mar 27, 2021
- Messages
- 20
It fits perfectly in the space. It’s also about the same distance from the exhaust as it would be in the original location. But the oil light goes out much faster like thisI was always wondering what to do with that space!
Yeah, my filter was always "dry" when I removed it. It was emptying itself for sure.But the oil light goes out much faster like this
I’ve learned to change the oil with it cold. Burned a few holes in long sleeve shirts. My original plan was to point it straight down but that was as close as I could get. I used that filter because it’s the same as my ford truck. And had a few at home alreadyTopping off and changing filter, I could see that, although IMO draining still has value. Whatever isn't caught by the filter is still circulating around... though not for long. Just what I'd do.
But wouldn't it be easier to just use the original filter and spin it off/on? Now you have to reach behind that header.
I always did mine stone cold because of that exhaust manifold... no way I'd do this one on a warm engine.
Makes sense. For a bit I had three cars taking that filter, so no big deal to have a stock.I’ve learned to change the oil with it cold. Burned a few holes in long sleeve shirts. My original plan was to point it straight down but that was as close as I could get. I used that filter because it’s the same as my ford truck. And had a few at home already
I'm not even mad, that's amazing
Helluva dry start if the ADBV goes bad tho
What was the motivation for this most BITOG of engine mods?
I keep an eye on the oil light and I pre filled the filter held almost exactly a quart. I do plan on changing the filter every 5k probably going to find something cheaper than the Donaldson to use regularly. My motivation is mostly the hilarity of it all I probably have the only Camry with a 6.7 power stroke oil filter on itI'm not even mad, that's amazing
I had thought of that. But the filter thread adapter made the project much easier and I think less prone to leaks but time will tell on that. As a bonus the Donaldson filters 99% at 15umI'd thought of making a custom machined remote mount to increase oil capacity/service life by using those heavy duty size filters. Would likely do it to a truck someday. Probably would try it too on a fun project car. Thanks for sharing.
I plan on cutting the filter to take a look at 5k (290,000 mi) may try the wix next.I had thought of that. But the filter thread adapter made the project much easier and I think less prone to leaks but time will tell on that. As a bonus the Donaldson filters 99% at 15um
