i picked up one of these off the side of the road. took it home and it did 2 things. it did not pump which i tracked to a bad unloader valve. $5 amazon part fixed that. 2 it would pop the 15amp circuit breaker when pumping up. i decided to bypass the breaker and then checked the amp draw with my meter. it drew around 15.5 amps.
So do these small compressor draw this much amperage normally? after bypassing the breaker it works as it should and pumps up quickly.
Harbor Freight Tools – Quality Tools at Discount Prices Since 1977
Harbor Freight buys their top quality tools from the same factories that supply our competitors. We cut out the middleman and pass the savings to you!
www.harborfreight.com
