just curious about recycle oil and where it goes
louisiana
What happens to all the oil we recycle. Seems like a lot. What is being done with all those gallons and gallons of recycled oil?
Typically burned as fuel. Which is good, that's virgin crude that doesn't get burned in it's place.
Some gets recycled back into lubricants.
Safety Kleen recycles a LOT of oil back to engine oils again. Northland is another outfit that recycles a lot of oils back to various lube products.
Originally Posted By: JDW
The oil I turn in is used for Asphalt I have been told .
I remember, as recently as the 1980s, seeing used oil sprayed onto dirt roads to keep the dust down. This was around New England logging roads.
Some is also used as cutter stock to thin heavy fuel oil.
Properly re-refined oil has been hydroprocessed to convert the oxidized parts back to saturated base oil. It can be OK. Many government fleets use re-refined oil, and their results are good. The old method of just filtering and re-additizing old oil wasn't good, and may be ancient history.
I've got around 4 cases of safety clean ecopower sm oil around the house in my stash. Seems to run fine in all my cars.
