I know its not single stack, but while you're in the gun shop check out the SCCY CPX 2, dbl stack and 11 rounds counting the one in the tube.
I should have added here they sell for $239.00. Just bought the 2nd one today.
How much have you shot it? I've looked at the CPX-2 before, but not with too much seriousness. But the more I look at it, the more I like it.
It says the trigger is 9 pounds, double action only. That sounds slightly heavy; my Kel-Tec has a 6 pound trigger. Is it still pretty easy to stay on target with that heavier trigger? And is it a true double action only, with second strike capability? My Kel-Tec is "double action", meaning that it does pull the hammer back and release it with the trigger pull, but the slide half-cocks the hammer, and the trigger can only pull the hammer back from that half-cocked position. If a round doesn't fire, you cannot strike a second time because the slide wouldn't have cycled.
Thanks.
