I just started the 2000 Corolla on the MMO, I used 4oz. this time. The tank is 13 gallons, usually only 10 or so to fill up. I think 3oz for continuous use will be good, does that seem reasonable?
YUP!
Thanks for your response, I know you now have extensive experience with MMO
All of the positive feedback has got me intrigued and I need this little car to last me a long time.
I'll also report back w/ mileage numbers.
I don't try something unless I research it to death, then I don't post about it here unless I absolutely can say without a doubt that I like the product and can back that up with real-world experience with it.
I do the same thing! After more years than I care to remember I've been using MMO, and always had good results and experiences with the product. I'm glad to see others are using it and getting similar results.
A few suggestions I give to first time users: use the suggested amounts or even a little less, more is not better! Give the product a chance to work, on occasion people get instant results, for others it takes some time. Keep a log of MPG and tweak the dose up or down and check results. MMO is not going to ruin your engine! During the winter months I like to use the total recommended dose, I really believe it helps keep the top end of an engine protected during that first start on those cold winter mornings.
