Oil change on 2001 civic with some engine noises
by llmercll
19 minutes 7 seconds ago
Valvoline Cerulean
by Ramblejam
21 minutes 55 seconds ago
Highlander timing belt
by Carguy21
43 minutes 28 seconds ago
Saw my old Saturn Wagon in the wild!
by eljefino
Today at 04:23 PM
Went with Primewells
by Eric Smith
Today at 04:06 PM
121R Battery Group Size Alternatives ?
by neilwestlawn
Today at 03:52 PM
PARTS MASTER #67060, unknown miles, 2013 RAM truck
by car51
Today at 03:41 PM
All you ever wanted to know about carbon ceramics
by dparm
Today at 03:36 PM
New, UNUSED PSL-10241 CUT OPEN
by car51
Today at 03:27 PM
How bad is this?
by cnl64590
Today at 02:21 PM
Mag1 or ST Dino: what would YOU use?
by car51
Today at 01:54 PM
Ustria?
by Pontual
Today at 11:48 AM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
104 registered (69GTX, afoulk, 2cool, 1989outlaw, 2002 Maxima SE, Atesz792, 10 invisible), 1620 Guests and 198 Spiders online.
56834 Members
66 Forums
244322 Topics
Page 1 of 3 1 2 3 >
#1193076 - 07/13/08 09:16 PM Lucas Transmission Fix
RedOak Offline
Loc: West Virginia
Does anyone have any information of what the composition of this product is? I was not able to download their data sheets for some reason. They claim no solvents or kerosene carrier, and it claims to do some of the same cleaning as auto-rx would do for a transmission. The only difference that is readily apparent is the Lucas may change the viscosity of the atf where the auto-rx would not. We all know the good benefits of auto-rx, but how would this Lucas product stand against it. They make a fuel system cleaner that I tried that is also eco friendly that claims to improve mileage. On one of my vehicles a 94 ford 351 windsor it did on the other it actually dropped the mileage. That product seems similar to Fuel Power.
Conventional oil keeps my engine clean.
#1193208 - 07/14/08 12:15 AM Re: Lucas Transmission Fix [Re: RedOak]
c3po Offline
Loc: Maryland
It does not even come close to doing what Auto-Rx does, I used Lucas Transmission Fix and it did not do a thing. Auto-Rx turned my trans fluid a very dark burgundy color and it left a layer of junk on the bottom of my transmission pan.
#1193572 - 07/14/08 03:19 PM Re: Lucas Transmission Fix [Re: c3po]
RedOak Offline
Loc: West Virginia
Well I think the Lucas product does clean as advertised but it might change the chemistry of the host atf which the auto-rx will not. Both products claim to clean and if c3po you found dirt on the bottom on you pan it did some cleaning with the help of auto-rx. The question is if the Lucas product will do as good as job as auto-rx. I at this point after thinking about it doubt that it will. Any further oppinions?
Frank?
#1193658 - 07/14/08 05:04 PM Re: Lucas Transmission Fix [Re: RedOak]
Tempest Offline
Loc: Las Vegas NV
48cSt@100C? Yes, it will change the viscosity of your ATF. It's probably mostly thick oil and polymer to thicken the oil and a sprinkling of adds. I would not want that in my trans.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
#1193683 - 07/14/08 05:30 PM Re: Lucas Transmission Fix [Re: Tempest]
c3po Offline
Loc: Maryland
I did Lucas Transmission Fix 2 years before Auto-Rx and when I changed the fluid there was nothing on the bottom of the pan. These are just my observations and it did nothing for my trans, now Lucas Gas Treatment is another story. I thought Lucas Transmission Fix was supposed to give better shifting, maybe I was wrong about the cleaning, but my observations are just observations and not scientific fact.
#1193806 - 07/14/08 08:12 PM Re: Lucas Transmission Fix [Re: c3po]
RedOak Offline
Loc: West Virginia
Well I still have some tranny shudder in my automatic and should have waited for my auto-rx which is on the way. I added 12 oz. of the lucas and it seems to have helped take most of the shudder and slipping out but it is not all out. I will add the auto-rx as prescribed and run about 1,500 miles and flush the whole unit again. I flushed the tranny about 600 miles ago and they refilled with Motorcraft Mercon V. It took away about 50 percent of the shudder and the Lucas has helped reduce a little more but I think the auto-rx will clean out the touque convertor and bands to make it run well again.
#1193871 - 07/14/08 09:37 PM Re: Lucas Transmission Fix [Re: RedOak]
c3po Offline
Loc: Maryland
Red Oak, do you have a transmission cooler on your vehicle, meaning an external cooler, my 2004 Mercury Marauder came with 1, this helps a little bit with decreasing the shudder. I think there is a product called LubeGuard Red that is supposed to help with the shudder. On my Marauder I have a little shudder and from what I have read I would have to get something like an X-Cal 2 tune, basically reprogramming the computer but I am not going to do it because I have read that sometimes people have gone out to start there car's in the morning that have had this tune and there car did not start. I will go out on a limb and promise you this, after doing Auto-Rx in your transmission it will feel like a new transmission, just make sure to clean the bottom of the pan when the 1500 miles are up.
#1193895 - 07/14/08 09:57 PM Re: Lucas Transmission Fix [Re: c3po]
RedOak Offline
Loc: West Virginia
Yes external cooler. Before totally flushing the whole system with new mercon v the shudder was bad. After the flush it helped but still there. My gosh when I added the Lucas yesterday it was so thick and the temperature was about 90f. I thought about reprogramming but my opinion is the tranny is just dirty, especially in the torque converter and the bands. After the auto-rx run I may use a full synthetic mercon V made by Valvoline. It may be a tick better than the motorcraft which is just a synthetic blend, I believe. Thanks for your comments c3po.
#1193990 - 07/15/08 12:21 AM Re: Lucas Transmission Fix [Re: RedOak]
c3po Offline
Loc: Maryland
If you are looking for a full synthetic transmission fluid I would also check out Redline D4 and Amsoil ATF which meet and exceed Mercon V specs. How many miles are on your transmission. I think that Valvoline Mercon V is not 100% synthetic, both Redline and Amsoil ATF's have better flash and pour points. I would ask Pablo or Gary Allan.
#1194020 - 07/15/08 02:23 AM Re: Lucas Transmission Fix [Re: c3po]
RedOak Offline
Loc: West Virginia
123,000. Original owner pulled horse and cattle trailers. Truck is in excellent shape, not a spot of rust very well taken care of. Came from North Carolina. I just bet the high temps. from the towing had a hand on the deposits in the transmission. I just do not believe anything mechanical is wrong other than needing more cleaning being a 94 with a 351 Windsor. Motor runs flawlessly. Now on auto rx rinse phase with one to go. Four speed electronic automatic known to be particular with atf fluid. Your idea about Redline or Amsoil is a good one. Thanks.
#1194162 - 07/15/08 10:16 AM Re: Lucas Transmission Fix [Re: RedOak]
c3po Offline
Loc: Maryland
If your automatic is sensitive to trans fluid you want to make sure that whatever fluid you chose you get as much of the old fluid out.
#1194613 - 07/15/08 07:28 PM Re: Lucas Transmission Fix [Re: c3po]
RedOak Offline
Loc: West Virginia
That is for sure. I thought the Lucas tranny fix was helping a bit but my inspection sticker was dead so I used the truck on my daily travels after the inspection. My gosh the thing is slipping now worse than ever and has terrible shudder. I only put a few oz.of the Lucas in and initially I thought it was operating better. But today after 200 miles the thing is worse than ever. When I came home, luckily there was my bottle of auto-rx I had ordered. I checked to make sure the fluid was not over full while the engine was operating and put 6 oz. per instructions in the tranny. Well I guess we will see what happens. I think it will work out that the thing is just dirty. I will run 1,500 miles then do a total flush and put in some redline or amsoil that is rated to mercon V. If this does not work I am afraid there may be some mechanical issues. I will keep updating this post. I would not put the Lucas product in anything again. It just made it worse.
#1194775 - 07/15/08 11:53 PM Re: Lucas Transmission Fix [Re: RedOak]
c3po Offline
Loc: Maryland
When you put in the 6 ounces it does not have anything to do with the level of transmission fluid, remember Auto-Rx is not tranny fluid or engine oil it is a metal cleaner, have you checked your transmission filter, hopefully you have the screen type and not the felt type. I think that Auto-Rx will eventually clear everything up. Have you looked at the bottom of the pan for any signs of metal debris.
Edited by c3po (07/15/08 11:58 PM)
Edit Reason: Made Mistake
#1194836 - 07/16/08 05:29 AM Re: Lucas Transmission Fix [Re: c3po]
RedOak Offline
Loc: West Virginia
Screen type filter, I did not see the bottom of the pan when the ford garage did the complete flush removing all old atf and adding new motorcraft mercon v. I asked them what it looked like and they said it was dirty but they had seen much worse. They utilize the machine that removes all the fluid even out of torque converter. I ran to town last evening after installing the auto-rx and the thing settled down. It still slipped a bit but it was also not as hot as it was yesterday it the mountain driving, I will park the company truck another day a use this truck to advance along the 1,500 miles to find out if it will help. I still am confident this will do the trick. I should have waited just two days instead of trying the little bit of Lucas which at least in my case made my truck act more like a kicking bucking misbehaving child,
#1194954 - 07/16/08 09:49 AM Re: Lucas Transmission Fix [Re: RedOak]
c3po Offline
Loc: Maryland
The screen type filter is good because Auto-Rx will liquify everything and not clog up the screen, just keep driving the truck as much as you can.
Page 1 of 3 1 2 3 >
