I say do what the manufacturer tells you, ESPECIALLY with vehicles still covered by the warranty. Otherwise, if you go too thick or thin - it then becomes your own fault, not the manufacturers.
With older vehicles, do what the manufacturer tells you* and only bump up a grade if you notice excessive consumption,** or will be working the engine hard (e.g. very heavy towing in hot conditions).
Don't follow recommendations from oil manufacturers to use 20w60 (or 25-70!) in a car that is daily-driven, and only relatively young at 200,000km... This is simply marketing (or scare-mongering about "worn engines") and will more than likely cause more problems that it solves.
As I've said before - if using thin oils were to cause the problems some people suggest they do, and were ruining 4y/o Toyotas with under 100k on them, I might agree that there is an issue.
Fact of the matter is that this isn't happening, and I have not seen or heard of any class-actions lawsuits as a result of this recommendation.
There have been rumblings about sludge - but if your usage pattern is so harsh as to induce it, then you ought to be servicing sooner per the recommendations of (most) manufacturers in the Owner's Manual... This brings me to this point: R - T - F - M!
At the end of the day, plenty of people have gotten their cars to stupidly high mileage with thick oils, thin oils and anything in between. I think it comes down MORE to how well you take care of the car as a whole, instead of fussing over oil.
You might change the oil every fortnight, but if you neglect your cooling system, steering/braking/clutching hydraulics, electrics (and so on), then the rest of the car might come apart before any lubrication failure takes place.
In other words: A car that is regularly serviced (in all aspects, not just oil/filters) is a car that is long-lived.
Footnotes:
* Unless you have evidence to the contrary - i.e., we now know that 3 months/3000 miles is pointless for the most part.
Same with changing viscosity for summer and winter with modern synthetics - although do this if it makes you feel better.
** Some engines may respond to a thinner oil with consumption issues, provided you aren't going below the minimum viscosity required for the engine.
Footnotes:
