Working on an '02 Forester normally aspirated.
Regarding the evap purge valve in the engine bay on passenger side of engine kinda tucked under the intake manifold: should you not be able to blow through it in either direction?
I cannot blow through from firewall to intake, which I believe would be normal operational flow. I can also clearly tell it opens/closes in test mode.
However I CAN blow from intake manifold port toward firewall in either electrical state.
I don't know if this is normal, or signifies a weak valve which would potentially cause a "small leak" code.
