Originally Posted By: KitaCam
failing ball joints and other suspension parts can fall off the car and dismount the wheel
This is quite true, and a failing balljoint should be replaced.
But let's be realistic and keep our alarm for situations where alarm is warranted. Your bolded and underlined insistences that engineer20 is endangering little kids by his failure to replace the balljoint just makes you look like you're irrationally angry that he's not listening to you.
It may seem counter-intuitive, but a balljoint that separates is not normally something that causes collisions or deaths. I have seen many failed balljoints, all of them of the load-bearing type. Damage ensued to the vehicles -- often expensive damage -- but nobody was ever hurt, just frightened.
Engineer20 is like Joseph: a lost cause. I also believe he is less than truthful. Much less.
1. Having personally experienced a wheel assembly literally fall of the axle I can testify the danger of not replacing failing suspension parts....this is NOT an irrational concern when someone has no clue how to maintain a car and refuses to take the advice from those who do, whether mechanics or forum members.
2. He claims that a Toyo PCV valve would cost him $13-14 in Michigan, so I fact-checked that and Spartan Toyota of East Lansing lists the valve @ $4.22....so yes I do believe E20 is much less than truthful....
3. The bold and underlined words was simply to identify what I was referring to in his paragraph of run-on sentences and ideas.
Kita, why are you letting E20 push your buttons? Just ignore him and let this stupid thread die.
