Originally Posted By: NHHEMI
Originally Posted By: Wolf359
You should read the deflategate wiki. There was only one ball that was under 2 PSI. Gronk spiked a ball. There was also an official selling game balls and was later fired. The other balls were 11.5 PSI. They were at the proper pressure when they were tested inside. If you read the rules, it doesn't really state what the temperature and pressure should be when they're tested so they were in spec at one point. The rules don't actually have a spec for weather.
There were also some initial miscalculations on the pressure drop, it's 12.5-13.5 psi inside the ball, but you also need to account for the atmospheric pressure when doing the calculations so some initial reports that said that the temperature drop wasn't enough to account for it later corrected themselves and said yes it was possible.
I think Mr. Kraft is still waiting for an apology.
Contradicts everything I have seen reported. 10 of the 12 balls were in the 2 PSI range off not just 1. Gronk spiking the ball is 100% immaterial.
Mr. Kraft will have a long wait I think. Even if they can't prove it I seriously doubt any apology is coming as the balls were under.
If the Colts were caught cheating with the ball air pressure during the game would you be so willing to dismiss it? I think not. Patriot's fans make me laugh the way their team can do no wrong but they sure do cry when something goes against them.
You had to really follow the story. I think if you read all the stuff that first came out, it all changed later. The stuff on there now is pretty much the sum of all the reporting that was done. The initial reports were that it was more balls and the 2 psi number. The later reports was just one ball and just one psi for the rest of them.
It's why juries have to listen to all the evidence and it's funny when lay people have a different opinion because they didn't listen to all the evidence so they only have part of the story.
I guess Mr. Kraft won't get an apology from you either?
