Originally Posted By: Hokiefyd
Originally Posted By: CapriRacer
Yes, the only property affected by having a directional tire rotate the wrong direction is wet traction. Grip and wear are unaffected.
Wet traction or hydroplane resistance?
First, wet traction and hydroplaning resistance are difficult to separate. But you can test a tire's wet grip by keeping the speed low, the water depth low, and the tread depth high. With those conditions, hydroplaning is a very small component compared to the grip between the rubber and the road.
Needless to say, substantially increasing the speed, substantially increasing the water depth, and a well worn tire, hydroplaning resistance is greatly affected. But, again, the difference between rotating one direction as opposed to the other direction results in only a small change.
