Originally Posted By: mrcoolguy
Drag races. I also read that Redline doesnt burn oil as much as M1. Is this true? and is it related to shearing
How much 'hot-lapping' during those track days?? (Just so you know, most people on here refer to open tracking/road racing as "track days", NOT drag strip; rental days/test and tunes, time tials/brackets/heads up/etc.)
Red Line has one of the lower NOACK volitility numbers (depending on which weights) out there if that is what you are meaning by "burn oil as much".
But if you have ANY valve seal/seat, or piston ring pack problems, basically NO oil is going to help you in this regard,
especially at WOT, foot flat on the floor even during shifts, 1/4 mile runs.
BTW, either straight M1 0W-40, or a mix of that and the M1 0W-30 (50/50, or 70/30) would probably stand up just as well for your uses as Red Line, and cost less $$$ if you can get it on sale somewhere.
These two M1 oils above are generally considered to be a higher grade than the 'regular' M1 stuff, and maybe even over their own high mileage oils. (They are NOT that much "less" of an oil than Red Line, and may even have some of the same POE/group 5 base stocks which RL uses, albeit probably not in as high a concentration.)
