I'm curious how xW-30 made your car stall, but 20W-50 doesn't...?
He's running very low on oil to the point it became sluggish even stalling.
Now I'm REALLY confused...are you saying he's running the oil so low that the motor is on the verge of seizing?? If not, I've never heard of a motor stalling simply because the oil was low...
I was responding to this response only...
Originally Posted By: JimPghPA
I had to go to something thicker than a XW-30 because it burned and leaked 30 too fast, and it would sometimes stall on a very hot day. With the 20W-50 I do not have to add oil as often, and I do not have to smell the leaking oil burning off, and it does not stall on hot days.
Then I provided a reason why it could be possible. That a larger volume and flow of thin is required to maintain a film between moving parts vs a thicker oil. Not enough film it could stall from being too tight, but not seize.
Or maybe its just as simple as hes not burning as much oil and catching it sooner. Either way its better than running out.
Quote:
You`re absolutely right. Engine runs critically low on oil,loses the compression it needs to run,therefore stalls. MUCH better than having it seize up!
That's a stretch if I ever heard one, seen several engines run without oil till pieces started flying out of the bottom end... A buddy melted the rod bolts on a couple cylinders of a Ford small block, had plenty of oil in the pan, but pump seized... That one got so hot it burned the paint off the oil pan down to the sump where oil level was...
