bkrell,
I don't think MMO is a potent solvent per se. I look at MMO more as a lube with some, albeit little, cleaning ability (although it does seem to unstick rings and lifters). The Chemtool I would fully expect to dissolve sludge pretty much on contact. But that's its design. Having said that, I would also expect the Chemtool to be less safe on engine internals than the less potent MMO when used over the long term.
Don't get me wrong, I am interested in the Chemtool, based on your posts about it, for cleaning carbon off my piston tops. See this post: http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=5;t=003935#000000
I have the same issue as sky jumper, and even the same model car (but mine's 2 years older I think). How would you recommend using the Chemtool? Sucking it through a vacuum line like Sea Foam, or adding an oz to each cylinder and letting it soak? I have used several different gas additives, including MMMO, Lucas, Techron, Gumout, Pyroil, and Prestone Syn Fuel System cleaners over the past several years. I've also Sea Foamed through a vacuum line several times with less than stellar results according to visual inspection (although the car idles smoother and throttle response is crisper afterwards. Just that visual inspection shows minimal improvement). But the carbon is still there. And naturally, I don't want it there.
I notice you're from S'port. I used to patrol Cedar Grove a few years ago. I'm just a stone's throw east of you in Webster Parish. Nice 80 degree weather yesterday, wasn't it?
Any advice on the carbon issue is appreciated.
Semper Fi,
Dave
Semper Fi,
Dave
