Hi. I have 02 Honda Civic LX with about 48k miles. Manual specifically say that oil should be 5W20. It says that 5W30 could be used as a temporary solution but should be switched back to 5W20 ASAP. What would happen if I put 5W30 in and run it?? Would something brake? Why is manual so anal about it?
The reason I'm asking is because I started changing my own oil recently(using 5W20) and car seem to started growl and lost some power. Before I used to go to Fast Track oil change chain. They said they put 5W20 Mobill 5000, it was ok. Now car revs louder and feels a bit underpowered. Could it be possible that lube service was putting 5W30 all along instead of proper 5W20. That's why I'm experiencing such change all of the sudden? I just thought since I'm doing it by myself now, I would experience change to better, not to worse. Oils that i used so far were Mobil 1 5W20 and Castrol GTX 5W20. Thank You.
