Here's roughly what I do:
- use a vacuum pump or turkey-baster to drain the reservoir
- remove it (make sure the surrounding area is clean)
- fill cover/fill the hole with clean rags/paper-towel
- clean the reservoir and replace
- fill & cap the reservoir
Starting with the corner furthest from the brake-master:
- put a box-end wrench over the drain-nipple
- attach my drain bottle to the nipple with the hose
- - make this out of a juice/water/pop bottle if you don't want to buy
- - buy some nylon (or similar) clear tubing from the hardware/parts store
- - drill two holes in the bottle cap (one small breath hole, one for tubing, snug fit)
- - insert the tubing through the cap, make it long enough to touch the bottom of the bottle
- crack the nipple loose 1/4 - 1/2 turn
- slowly pump the brake pedal in-out a set number of time (10?) or have some else do it while you watch the bottle/tube
- keep the reservoir filled
- when clean fluid is coming out, tighten the nipple
If you have a second person to help, then:
- tell them to apply brake 'pressure'
- crack open the nipple until you see fluid flow
- close when it stops (or when the driver tells you 'done' or 'floor')
- driver then slowly pumps the pedal until they feel 'pressure', and hold it
- repeat
Now move on to the next closest corner and repeat.
- repeat
