Originally Posted By: martinq
Originally Posted By: FutureDoc
if you are opening something up frequently enough, then why use something that is not re-usable?
Simple, gaskets are not re-useable (in general). Also, RTV is much cheaper.
In some situations you can get away with it (non-critical). In some situations you can re-use if you treat/dope the gasket with a type of sealant. In most applications the gasket should not be re-used.
Not necessarily. If it is a rubber or multi-layer rubber gasket that is not distorted and not excessively old, then you can definitely reuse it. I would no re-use a cheap cork gasket. Now, if you were dropping the pan every couple of years, reuse it if there is not deformation, it if has been 10-12 or more years, then it could be replaced.
