InfmousCornholio
Originally Posted By: clinebarger
I have the feeling this is not going to end well?
I Have some 4L60-E questions for you. I'll PM, ok?
Post a new thread, I will try to help.
Have you Barred the engine over to make sure it's not locked down, I see rust on the cylinder walls, Don't force it....That will break piston rings.
Sure thing.
Engine turns.. and, as far as I can tell, is flat. Compression test before teardown had water in one of the cylinders, actually broke my 1st compression tester over it.
I would like to ask "dumb" questions.. can I get taps ad dies at Harbor Freight? I'm still trying to determine which one is for my head bolts..
I tried giving this helper mechanic the benefit of the doubt multiple times, now, with it less HOT outside (you know mental illness HATES heat even a little bit of, right?) Then I'm down to do it all by my lonely..
Sure thing.
