First he breaks the bezel, which already had a crack but could easily have been removed intact. Next up, use the biggest screwdriver possible to pry out screw covers because this makes it easier to mar the panel. Then he mangles the tab at the front of the window switch before removing it properly from the back first. This is good because everybody likes having extra rattly noises. Now, on to yanking the panel off and hoping it doesn't crack before looking and seeing there are some plastic retainers that could have easily been pried out with a suitable tool.
This is about the time I stopped watching because I'm pretty sure he was about to remove the actual door handle with a logsplitting maul and I would feel really embarassed for him if he does that on camera.
