Well, you guys have influenced me.
On my wife's Xterra I just did an oil change.
No filter change.
It took maybe 10 minutes, no jack needed.
It has taken her 15 months to go 5,000 miles.
It sees quite a bit of city, and a little highway. However, it is normally pretty hot outside (90 degrees is a cold front these days) so it gets up to temp pretty quick, and it went through 2 quarts of makeup oil over that period of time.
The RP oil filter is designed for long intervals, and the engine is very clean through the fill hole. She was the original owner, and was extremely diligent to have her oil changed before 3,000 miles before I met her.
I will post pics of the filter in... well... perhaps another 15 months.
Changed out PP 5w30 for Napa Synthetic 10w30.
It having a 3 quart capacity, excluding the filter, I like the individual quarts that I can pick up at Napa along with a Platinum filter (Which I will go to next OCI and use 2x).
BTW, I ment to take an oil sample but the oil was done draining into my dirty oil pan before I realized that I should be taking a sample.
I will try to remember that in 15 months also.
No filter change.
