No offense, OP, but the "lack of friction" you describe is throttle programming, NOT superior engine design. Your car, like many these days, holds the throttle open a bit whenever you are underway, even if the pedal is lifted.
But it sounds like a fantastic candidate for an aftermarket programmer. Most cars respond well to them and become much more fun to drive. Some even increase their fuel economy...
If you're talking to me... I trust the Ford engineers and the SAE over those who elude to me being an idiot.
http://articles.sae.org/10714/
Why
wouldn't a 1 liter engine have less friction losses than a much bigger engine with more cylinders?
Ahem, the word you were looking for wasn't "elude". Perhaps it was "allude"?
But regardless of how your feelings got hurt, no one was arguing your assertion. Simply pointing out that your foot no longer controls that throttle, the computer does! And what you describe is a common issue on many modern cars. You did what anyone can do, missed the real reason entirely and got caught up in the hype.
Grow some skin, man...
My feelings aren't hurt. I don't care what anyone thinks about me. This is how this car feels to drive and that was my point. My 1.6 MINI Cooper also had an electronic throttle and this effect still isn't NEARLY as pronounced as it is in this engine. Not even close. How is that possible?
Ford can tune their DBW as badly as they want I suppose... Even my Ford with a cable throttle still uses some tricks to rev hang a little at normal rpms. At higher rpms and throttle openings it seems to smarten up and the revs drop as soon as I chop the throttle.
Also the 1.0 probably does have a larger flywheel in relation to its internal friction than most engines, so its not going to spin down to fast. I feel your pain as my Tracker has a low 1st and what seems to be a heavy flywheel, plus a semi weak synchro for 2nd, so I usually just short shift 1st and use a bit more throttle in 2nd. Your motor has good torque at low rpm so it doesn't hurt to use it.
I guess you could try double clutching too, I find its not worth the bother, but maybe in your car it would be?
