Need advise on a piston soak
Hi all, I'm new here - first post. I need to ask about recommendations for a piston soak for my 1991 Mercury Capri XR2 Turbo, 1.6l DOHC Intercooled.
A little background:
I've had It for abut 4 years and have run it from right at 100k to about 148k now. It started using oil a few years back, didn't use more than most other cars I'd had, maybe 1qt/1800, but it began using about 1qt/1000 and I could see clouds when I accelerated hard- thick blue ones. I investigated and found out it was a bad turbo shaft and if I kept my foot out of it, the oil usage was not as bad, 1qt/1200, but if I floored it, I figured out it lost about a cup every time I did so, so I babied it for about 6 months until I could find the parts to replace the turbo.
With the new turbo on, I was still using oil more than I used to, just not so visibly (faint smoke on full throttle). I also had some nasty oil leaks and ended up pulling the head and sending it out for valve stem seals and a decking. I put ARP head studs and a Cometic head gasket on it along with all new seals last summer. That stopped the leaks, but the burning continued, but not thru the turbo and not thick blue.
Well, the oil consumption has steadily gotten worse. Back when I had the head off I did my own soak, not even knowing about what to call it. I just used sea-foam on the piston tops and tried to let it soak past the rings for a weekend, working the pistons up and down some.
IDK if it helped any, she runs terrific but still uses oil - now at a steady qt/500. I still see no smoke at startup, the induction piping is clean (not a turbo seal) and I see that it all comes through the PVC hose (blow-by). I have the best PVC valve recommended for it and have tried others, but none stop the flow. I put a catch-can on the line and I trap about a cup in 500 miles.
Oil history: After I got it I started using Mobil Super Synthetic, mostly 5W30 because of our cold climate in Michigan. Eventually, one mechanic I talked to convinced me to use a semi-synthetic high-milage oil like Valvoline sells which I am currently running (5W30 in winter, 10W40 in summer).
I started thinking how I might fix this and decided to try putting sea-foam in the crankcase 300 mi before a change. This didn't seem to help so for one more attempt I just put it in again and it is time to change it. That's when I came across all the info here on this site and started thinking about trying better solvents. I picked up some B-12 Berrymans, and just received a quart of Kreen I ordered last week. The eBay seller who sold me AC Delco Top Engine cleaner cancelled my order on me after receiving my payment (thankfully refunding me but costing me time getting started on this). I also read about some of you using Break-Free CLP gun cleaner so I received a shipment of that as well.
Should I order the AC Delco Top Engine cleaner again from elsewhere?
Here are my numbers...
Dry (cold too) CYL 1 (150) CYL 2 (149) CYL 3 (133) CYL 4 (155)
Wet (cold too) CYL 1 (172) CYL 2 (180) CYL 3 (170) CYL 4 (180)
She never smokes when starting, only when the RPM is in the 4000-6500 range and that is not much (light maybe blue, but faint). The other day she started on 3 cylinders and this rarely happens (might be a bad plug wire) and when it does it goes away in a minute. I was in a hurry to pull out of work and on 3 cylinders she smoked like a house on fire, but when I shut her off for a moment and restarted, she was back to normal and clear on 4 cylinders. That dosen't happen all that often, I should do a tune up though. She has about 30K on NGK G-Power Irridums, wires cap and rotor.
What kind of soak should I do? I was going to follow Trav's method, but I have the Break-Free, Kreen and BerryMans on hand, and the car currently has 3000mi oil in it (one Qt down - only a 3.4 quart capacity to start with so 2.4 in it and part of that is 180ml of Sea-Foam). I need to get started on this so any recommendation would be greatly appreciated...
Ron
Ron
