Quote:
What is the verdict on motor oil periodic flushes on newer vehicles. I know it should not be done on older high mileage and dirty engines or it will send bad junk into the upper cylander valves i think.
There is no harm in using periodic flushes. Reasons are, the solvent is typically low in volatility, so it evaporates quickly (typically during the draining of the hot oil). Any residual left over will not cause harm to the oil as the solvent will burn off by the time the engine gets to operating temperature.
Also, with all the posts on this forum, no one has EVER provided evidence that an engine was destroyed by "breaking loose" deposits and "plugging up" oil galleys.
There was one post on an old thread, where they used a 50/50 ratio of Mobil 1 and carb cleaner (they used it for a while, not just a quick one time use) and cleaned a badly running, badly sludged, truck engine up to the point where it was clean inside and no longer smoked, stumbled, or ran poorly.
