Distributed Computing?
Sat Nov 3 23:40:06 2012 | World Community Grid | No tasks are available for Help Conquer Cancer
Yet the other box IS unchecked... So it shouldnt download anything, right?
Sat Nov 3 23:45:52 2012 | World Community Grid | Resent lost task SN2S_AAU34080_0000194_0293_0
Sat Nov 3 23:45:52 2012 | World Community Grid | Resent lost task GFAM_x3N3Ma_PfODCase_0048375_0058_0
Sat Nov 3 23:45:52 2012 | World Community Grid | Resent lost task faah36371_ZINC12986425_xh2_xtal_01_0
Sat Nov 3 23:45:52 2012 | World Community Grid | Resent lost task qi776_00080_1
Sat Nov 3 23:45:52 2012 | World Community Grid | Resent lost task qi776_00081_2
Sat Nov 3 23:45:54 2012 | World Community Grid | Started download of wcgrid_sn2s_vina_6.20_x86_64-apple-darwin
Sat Nov 3 23:45:54 2012 | World Community Grid | Started download of wcgrid_sn2s_vina_prod_darwin_64.x86.6.20
Sat Nov 3 23:46:17 2012 | World Community Grid | Sending scheduler request: To fetch work.
Sat Nov 3 23:46:17 2012 | World Community Grid | Requesting new tasks for NVIDIA
Sat Nov 3 23:46:19 2012 | World Community Grid | Scheduler request completed: got 0 new tasks
Sat Nov 3 23:46:19 2012 | World Community Grid | No tasks sent
Sat Nov 3 23:46:19 2012 | World Community Grid | No tasks are available for Help Conquer Cancer
So maybe it wants to clear these "lost" tasks first? Also, is it wrong that there are no new HCC tasks?
Im just going to let it run the ones that it keeps giving me, hopefully it will refresh and this will clear up. Maybe there are no current HCC tasks?
After you do this, you may also have go into "Advanced" menu in BOINC Manager and select "Read config file" to force it to pull the config from WCG. Otherwise, BOINC Manager may be using your local config and ignoring the custom profile that you created on WCG.
Sorry. This is wrong. When you go into the "Advanced" menu in BOINC Manager, you need to press "Clear" to apply the web-based settings as opposed to your local ones.
But what Colt45 pointed out above will most likely fix your GPU processing problem.
I dont have a "clear" in the "Advanced" menu. When I do read the config file, I get this:
Sat Nov 3 23:53:50 2012 | | Re-reading cc_config.xml
Sat Nov 3 23:53:50 2012 | | No config file found - using defaults
Sat Nov 3 23:53:50 2012 | | log flags: file_xfer, sched_ops, task
Any ideas?
Any ideas?
Read config reads the local config file for any changes. If you don't have a local config file, the message you got is what is produced.
Under Projects "Update" reads the web config.
And to be clear, the local config settings ONLY override those in the web config if you've made adjustments.
IE, if you have a CPU usage percentage defined under your default config on the site and change that preference on your local machine, that's a local config option which overrides the options set globally through the website.
The list of projects, unless manually excluded through the local config file (which you would need to manually edit through a text editor and it sounds like your copy doesn't even exist, which is typical for a default style configuration) is retrieved from the website when you hit "update".
Sun Nov 4 00:07:05 2012 | World Community Grid | update requested by user
Sun Nov 4 00:07:09 2012 | World Community Grid | Sending scheduler request: Requested by user.
Sun Nov 4 00:07:09 2012 | World Community Grid | Requesting new tasks for NVIDIA
Sun Nov 4 00:07:12 2012 | World Community Grid | Scheduler request completed: got 0 new tasks
Sun Nov 4 00:07:12 2012 | World Community Grid | No tasks sent
Sun Nov 4 00:07:12 2012 | World Community Grid | No tasks are available for Help Conquer Cancer
Oh well...
Oh well...
I've stolen them all
I have 195 tasks in the queue LOL!
Cripes! What do you do? cache like 2 days worth of work?
My 7970 does a result a minute dude, that's like 195 minutes worth of work, LOL!
oh yeah... You just use them up!
Yeah, the card chews through them quickly, I was pretty surprised.
Cool. I might buy a 7950, and put it in the x16 slot I have at home.
Good choice. Apparently it can be OC'd to 7970 performance quite easily.
You can, but your CPU won't be able to keep up with it, and keep it fed with data. My 7850 keeps it's assigned core at or around 75% utilization, and that's a slower card with a MUCH faster CPU.
Yeah but it has to be faster than relying upon solely serial computing of my CPU. Plus then Ill have one key part for when I build my new system... One less thing to buy later.
Exactly
Still nothing... How am I supposed to help conquer cancer with my laptop GPU if they done send work?
You tried rebooting for S&G's?
