Originally Posted By: A_Harman
I wonder how well this is going to work out when the automakers refuse to honor warranties for engine failures. The clause "when used in accordance with the automobile manufacturer's recommendations" means the oil should be changed when the OLM indicates, not when the State of California says so. I suppose this means California fleet managers are going to have to buy expensive oils that can go 10k miles, but they'll have to do oil changes when the car says to. Are there any OLM's out there that go over 10k miles?
Disagreeing with your logic. Used in accordance means you don't race or go off road with cars, thats all.
No it doesn't. It means you change the oil when the OLM tells you. The OEM programmed the OLM, and it is their recommendation on when to change the oil, based on the duty cycle the car has been subjected to. When I take my Camaro to the race track, the OLM tells me to change the oil sooner. When I do mostly long highway cruises, the OLM allows longer OCI's. Short trips during cold winter weather also lead to short OCI's. It's way more sophisticated than an open-ended edict that you shall change the oil only when the state says you can.
A_Harman, if you're right, then this law does absolutely nothing. It says nothing. If OLMs or owner's manual override the 10,000 mile minimum, then this law might as well not be there. A correct interpretation of the law is found in the actual text of the law:
"This bill, on and after January 1, 2018, would require all automotive oil sold in this state to be certified by the oil manufacturer to achieve a minimum useful life of 10,000 miles when used in accordance with the automobile manufacturer’s recommendations"
