I'm with Vetteman. You are judging this product from personal experience and racing ad's which we all know is nothing more than a money issue. This doesn't mean they use it, but defiantly get paid to support the ad's for it.
You have no idea as to what it really is doing to your oil. As for never having any problems, well, we have people with 400-600,000 miles on gas engines not having ever pulled the valve covers off.. and all they used was a well blended oil with no additives. BTW, the guy with the nissan car that has 600,000 miles, is also the one that sells this oil to a hole pile of well know racers. Difference is, they don't advertise the oil because it isn't' being payed for, but yet, there is a slew of them. THIS FORM OF SELLING doesn't make it a good product, just a well known product.
There is some interesting points, first, I'd think maybe this type of additive would not go well for longer oil drains as many like to do. The remark of with the good well balanced oil would have possibly given you the same results or would it? I'd have my doubts that is was the only thing that made it go to that, just a good maintenance practice would accomplish this as well. Since you have no oil analysis with this product in there, you appear to have no way of knowing for sure what was happening, therefore, your opinions at best all you have to rely on. This is very common. Look at the amount of slick 50 users out there with no evidence of a problem. Same with stp users. All of these can lay claim to the same thing you can. Does it make them better or worse? Who knows, without anything to look at other than a well maintained engine by someone who takes the time to do proper oil changes with an already good oil.
As for comparison to auto rx, Not even close to the same chemistry and different application design. Consider the fact that the Resilone appears to have a pile of anti-wear additives as well as additives to effect viscosity of the oil among other additives whereas auto rx is designed as a passive soft cleaner that isn't designed to change the base oil chemistry. So, hammering on anything, trust me when I tell you, auto rx, 131 neutra, Lc, stp and many more have been looked at in the same way as you are seeing here so don't be put out due to this as it isn't personal, just when this topic has been gone through it will have been chewed up, swallowed and regurgitated more than once. This has nothing to do what is sold or not sold on here.
Is this bashing? Sorry, This is where we look more for facts. This is a NO SPIN zone when stuff like this is starting to be touted as a good poduct, then why worry if there is more than just a few stories of who used it, why not do some analysis and see just what does it do and can you run long drains, and how does it effect your base oil. I have seen one additive that some use it race cars and will work fine for that, but put into a regular car engine, and the oxidation levels shoot right up causing the oil to break down prematurly do to the fact it is designed to protect the race engine and then is be changed out, not run for extended periods of time.
Racing engines are different and using what is in a race engine is not the same in a stop and go car for extended periods of time like in a regular car.
