harry j
PER-1 must be an older number, I have been able to find it on the internet. It is in no way the PureOne filter, I'm sure the PureOne would has tested way better than 10% at 14u and 42% at 20u.
Quote:
Compare these efficiencies to the Eao
Eao 50% at 7u 98.7% @ 15microns
Donaldson makes 4" X 6" synthetic medial hydraulic filters that are 3 micron beta 200 and flow ~20GPM for ~$20. I wish the Eao's would filter like this, and I don't see a real reason they couldn't.
Quote:
Because they would clod up filtering at those efficiencies on the average gas engine.
Quote:
3 microns would be a bit extreme, but if you change your oil often, it could be tenable. I would like to see a filter of 10 microns at 98.7 %, it is doable evidently with a good oil flow. Too bad one isn't available. Custom filter anyone?
Quote:
mountravlr,
You write that the filter you use is considered by the manufacturer to be an 8 micron filter. Do you know what efficiency this was measured at?
