Need some help diagnosing a 93 Volvo 940 (2.3L 4 cylinder auto EFI).
Here's the prob.: over the past few months (give or take 6), the engine has died at idle at least three times. It's a pita to start it up again after it dies. Sometimes I have to wait 10 minutes before it starts up again.
While starting it, it sounds as though the starter has enough rpms to turn the engine over, but it's almost as though the car isn't getting enough fuel.
Changed fuel filter and had diagnostics done on the fuel system (pump), which seemed to be fine.
Tonight, after parking the car on a downhill angle (facing downhill), I went to start her up, and same symptom of cranking but no turn over.
I relieved the pressure via the schrader valve on the fuel rail...within 5 minutes the car started up again.
any help or suggestions are welcome.
Thanks.
Thanks.
