I went from a 20 grade to a 40 grade in my charger. When cold there was a definite difference in how the engine performed. There was more drag,I could feel it,but once the oil was at operating temp there was little to no difference.
But that's going 2 grades thicker.
Going a single grade thicker would be very hard to notice any difference once the oil was in service.
It's possible that the old oil had sheared enough that when the thicker oil was put in the engine felt a bit sluggish til hot but I seriously doubt that comparing an engines responsiveness with 2 oils being only a grade apart that a person could notice any difference.
But at the end of an interval using a 30 grade it's certainly possible that the oil sheared to nearly a 20 grade,so in reality it's comparing a 20 grade to a 40 grade which I then can certainly believe the change is perceptible.
I can certainly tell in my hemi's,every mod motor I put a 40 grade in was sluggish for the first 1000 miles,and last summer I tried out a 5w-20 in a very high mile 302 and the difference was absolutely perceptible. The engine definitely had more pep when light throttle inputs were used.
Not that I believe there is any real difference at wide open throttle however when driving light footed.
