Originally Posted By: 05foresterXT
Don't add more oil until it's down to the "low" mark.
What's the logic behind this?
The level indicated on the dipstick can fluctuate depending on how recently the engine was run, outside temperature, where it is parked, etc.
I discovered that if I park my car on the right side of my street, it reads a half a quart low. On the left side of the street, it reads half a quart high. One day when the car was parked on the right side of the street, I checked the oil, and freaked out and topped it off. Then when I took the car out to drive it, I noticed blue clouds of smoke when I would get on the throttle. Something was suddenly wrong with my car, and it seemed to have a severe consumption problem. I would put in oil until it reached the "full" mark on the dipstick, then I would burn oil and top it off.
Then one day I parked my car and checked the oil, and let it sit, and checked the oil multiple times, and I discovered that at first, it would read a quart low. After about 15 minutes, it was full. 2 hours later, it was at the notch above the "full" mark. It was then that I realized that all the oil my car was consuming was because I was constantly adding oil. I looked in my owner's manual, and it said not to top it off until it was at the "low" mark, and also not to add more than half a quart at a time. Since I have stopped topping off habitually, my oil consumption has dropped to maybe a half of what it was before.
I see. You were getting messed up by the crown of the road. If you would have started on a flat, level surface and checked it after letting it set overnight, which is more or less the preferred method, you wouldn't have had these issues.
But still, your point remains valid for someone who cannot. If the oil level is between the low and high point, then you are considered okay for continued use.
