Originally Posted by OVERKILL
The letter is an interesting read, the guy hawing a made-up grade (7.5W-40) with a billion ppm of ZDDP? Not so much.
The conclusion that the lubricant is inadequate doesn't make sense, given that as he noted, the valve spring pressure isn't overly high and it isn't a solid roller racing engine. Guys have experienced the issue even on engines run on much heavier additized oil, like M1 0w-40 for example.
I questioned, in one of the other extensive threads on this topic, whether the spring pressure was actually becoming inadequate once the engines got some miles on them, allowing valve float, damaging the rollers, causing them to spall the lobes and eventually lock up.
Roller motors are not supposed to have lofty oil AW requirements, that was one of the reasons they were introduced.
Per the analysis, something is causing the rollers to skid, spall, and eventually lock up and it isn't a lack of lubrication. It could be valve float, defective needle bearings in the rollers or insufficient lifter alignment control, allowing the rollers to scrub due to the body rotating. In any instance, a production street engine with a pretty mild cam shouldn't require Top Fuel levels of AW additives just to keep a cam in it. Given that most of the failures are 2015 and earlier and the lifter part #'s changing multiple times at this point, I expect FCA has/had a pretty good handle on the cause, as did/does GM, who experienced a nary identical issue with their AFM engines.
Agreed. I used to do camshaft failure analysis for the automotive industry. I don't see how the author can so categorically pinpoint the failure on lube choice. Overkill covered it pretty well. There are so many factors that can affect cam lobe wear. On one design I was involved with, the overhead cam was the last to get oil on startup. This resulted in a design change to include an anti-drainback check valve in the engine. Another problem can be poor break-in from insufficient phosphate coating. Half the author's report was spent talking about his qualifications.
