Forums Migration
Please read this thread
05 Dodge 4.7 L head gasket blown again
by vwmaniaman - 07/12/20 09:44 PM
How come every vehicle’s MPG computer is off?
by OppositeLocK - 07/12/20 09:37 PM
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
60 registered members (bbhero, Astro14, A_Spruce, alchargo, Bill_W, 92saturnsl2, 6 invisible), 1,591 guests, and 22 spiders.
Topics307,779
Posts5,317,665
Members71,917
5.7 HEMI Lifter/cam failure cause #5443245 05/31/20 02:38 PM
Skippy722 Online Happy OP
OP Online Happy
Saw this on YouTube, probably the best explanation I’ve seen on this issue so far. Thoughts from people smarter than I?
I wonder if it’s ultimately due to the changes they did when they added VCT, as I don’t really remember there being issues with pre-2009 hemi’s.
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: 5.7 HEMI Lifter/cam failure cause [Re: Skippy722] #5443251 05/31/20 02:43 PM
F
farrarfan1 Offline
F
That video was added to this thread earlier today. It's interesting to say the least.
https://www.bobistheoilguy.com/foru...c-lifter-failure-oil-related#Post2828939
2020 Ram 1500 Laramie 5.7L Hemi- Ivory White Tri-Coat Pearl
2019 Cherokee Limited 2.0L Turbo- Velvet Red Pearl
Re: 5.7 HEMI Lifter/cam failure cause [Re: Skippy722] #5443253 05/31/20 02:45 PM
Chris142 Online Content
Online Content
Uncle Tony has lots of good and interesting info. My favorite is turning pistons around to get more power. Makes sense with offset piston pins.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 5.7 HEMI Lifter/cam failure cause [Re: Skippy722] #5443254 05/31/20 02:45 PM
M
MParr Offline
M
Your 2019 most likely has updated parts. I have a good friend who is a Hyundai certified master tech and is certified to work on Chrysler products. He owns two Rams with the 5.7 Hemi. One is a 2011 Laramie and the other is a 2018 Rebel. He hasn’t had any problems. However, he runs 5W30 Mobil original instead of the recommended 5W20.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: 5.7 HEMI Lifter/cam failure cause [Re: MParr] #5443261 05/31/20 02:53 PM
OP Online Happy
Missed that, thank you!
I’m not worried, it just got my attention. I’ve been debating running 5w30 instead of 5w20 though
Re: 5.7 HEMI Lifter/cam failure cause [Re: Skippy722] #5443278 05/31/20 03:23 PM
O
OVERKILL Offline
O
Note that the issue has presented on engines that do not have MDS.
We covered the oiling system relatively extensively in the previous thread BTW.
2020 Jeep Grand Cherokee SRT Ravenol SSL 0w-40, FRAM Ultra
Re: 5.7 HEMI Lifter/cam failure cause [Re: Skippy722] #5443280 05/31/20 03:25 PM
I
italian68 Offline
I
I think he is right. My hemi ticks at low rpm when the engine is cold, exactly when cam lubrication is at it's lowest.
07 BMW 530i Castrol Edge 0w40 Mann
06 Ram 2500 5.7 QSUD 5w30 51515
05 Camry 2.4 0w20 51516
Re: 5.7 HEMI Lifter/cam failure cause [Re: Skippy722] #5443290 05/31/20 03:41 PM
dave1251 Offline
There were these issues dating back to 2004. It's a rare enough problem I would not sweat it. I'm on my 3rd Ram with a HEMI without the problem since 2004.
don't use.
Re: 5.7 HEMI Lifter/cam failure cause [Re: italian68] #5443303 05/31/20 03:49 PM
O
OVERKILL Offline
O
That's usually exhaust manifold studs.
Re: 5.7 HEMI Lifter/cam failure cause [Re: Skippy722] #5443305 05/31/20 03:50 PM
F
farrarfan1 Offline
F
If he’s right about it being caused by a design flaw then it doesn’t seem like we, as owners of HEMI equipped vehicles, can do much about it is there? If oil isn’t reaching the cam then how can using a different viscosity than what’s recommended by FCA going to help?
Re: 5.7 HEMI Lifter/cam failure cause [Re: farrarfan1] #5443310 05/31/20 03:54 PM
O
OVERKILL Offline
O
It wouldn't, as you astutely determined. Also, in the plenty of HEMI lifters that Iv'e seen pictures of, I've not, from failed examples, seen ones with the deposits and scuffs that his had. The bores are pressure lubed, not splash, it's the cam/roller interface that's primarily lubed via splash and it's certainly possible that extensive idling with low levels of oil sling could contribute to roller failure if insufficient oil is leaking past the lifter body and onto the lobe.
Re: 5.7 HEMI Lifter/cam failure cause [Re: OVERKILL] #5443318 05/31/20 03:56 PM
I
italian68 Offline
I
It's definitely a mechanical tick. Manifold gaskets and studs replaced on both sides. The tick goes away when revved as the pressure comes up and oil is thrown around more.
Re: 5.7 HEMI Lifter/cam failure cause [Re: italian68] #5443320 05/31/20 03:57 PM
O
OVERKILL Offline
O
It's definitely a mechanical tick. Manifold gaskets and studs replaced on both sides. The tick goes away when revved as the oil pressure comes up.
May just be a sticky HLA then.
Re: 5.7 HEMI Lifter/cam failure cause [Re: OVERKILL] #5443326 05/31/20 04:01 PM
I
italian68 Offline
I
That's possible. I have Valvoline Premium Blue Restore in the sump. Trying to clean things but hasn't been in there long. Tic is more or less the same so far.
Re: 5.7 HEMI Lifter/cam failure cause [Re: Skippy722] #5443327 05/31/20 04:03 PM
O
OVERKILL Offline
O
Excellent choice! Hopefully that helps.
