Forums Migration
Please read this thread
Which oil to use?
by HydroxZ - 07/07/20 11:02 AM
What oil for supercharged Lotus Exige?
by mkiv808 - 07/07/20 10:59 AM
Carb Metering Diaphrams
by Fordiesel69 - 07/07/20 10:30 AM
ABS Brake Bleeder/Pulsate Software?
by shibby6600 - 07/07/20 10:30 AM
NAPA Gold vs. WIX
by DCMotorsports - 07/07/20 10:11 AM
A/C symptoms-what to do?
by sipman - 07/07/20 09:59 AM
M1 and Liqui Moly - can I mix?
by ssoH - 07/07/20 08:47 AM
HF JACK-STAND RECALL EXPANDED
by demarpaint - 07/07/20 08:15 AM
Five Euro Car Myths?
by BMWTurboDzl - 07/07/20 07:46 AM
Trust Funds
by stockrex - 07/07/20 07:28 AM
3 on the tree
by Chris142 - 07/07/20 07:21 AM
ROCKAUTO selling old expired stock.
by nicholas - 07/07/20 07:21 AM
Amsoil SS 5w30
by mpgo4th - 07/07/20 06:57 AM
Water/Coolant Contamination?
by nastyc5 - 07/07/20 06:53 AM
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
Who makes the O'reillys trans filters ??
by GMguy84 - 07/07/20 05:00 AM
[Seattle Craigslist] Cheap Pennzoil 5w20
by SlavaB - 07/07/20 02:14 AM
HydroxZ, JDMorgan, sycboi, Chuck_Ellison, BakonBittz
71871 Registered Users
82 registered members (Anthony, bdcardinal, BAJA_05, 77GrandPrix, Barkleymut, AndyB, 5 invisible), 1,990 guests, and 22 spiders.
Topics307,548
Posts5,312,897
Members71,871
Vacuum pumps #5432250 05/18/20 10:40 AM
L
Local Color Offline OP
L
Not to remove fluids but to reduce crank case pressure - would this be practical for a passenger car?
Re: Vacuum pumps [Re: Local Color] #5432255 05/18/20 10:43 AM
supton Online Content
Online Content
Practical as in what? To increase mpg or to decrease emissions, for a certain cost?
I'll wager a "nope" regardless. If it could do either, it likely would have been done already. OEM's have a lot pressure to meet certain targets.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Vacuum pumps [Re: Local Color] #5432265 05/18/20 10:58 AM
R
ragtoplvr Offline
R
for a passenger car. No. Crankcase windage loss at 2000 RPM is quite small. At 8000 it is significant. Plus race engine are a little loose, and have very thin low tension rings, so can benefit from crankcase vacuum.
Rod
Re: Vacuum pumps [Re: Local Color] #5432270 05/18/20 11:00 AM
K
ka9mnx Offline
K
No. The crankcase is ventilated to the atmosphere. A little pressure is a good thing but introducing a vacuum into the crankcase is not.
Edit: Not referring to what you said, Rod.
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Vacuum pumps [Re: Local Color] #5432272 05/18/20 11:07 AM
CT8 Offline
There used to be vacuum pumps sold for race car use . I don't know it there is still a market for them?
2015 F150 2.7
2018 F350 6.2
Re: Vacuum pumps [Re: CT8] #5432275 05/18/20 11:12 AM
IMSA_Racing_Fan Offline
Such systems are used by drag racers. Not really needed on street engines.
https://www.dragzine.com/tech-stories/tech-how-external-vacuum-pumps-free-up-horsepower/
Re: Vacuum pumps [Re: Local Color] #5432280 05/18/20 11:21 AM
Online Content
Where do the drag cars vent the vacuum? Or rather, where does the other side of the pump blow air to?
Re: Vacuum pumps [Re: Local Color] #5432281 05/18/20 11:21 AM
T
Trav Offline
T
Your car already has a huge vacuum pump, the engine itself. You don't want or need additional positive or negative pressure (a vacuum) in a street engine as either can cause seal failure.
Some engines like diesels, forced induction and those with big cams require an additional pump for proper operation of the pcv system, brake booster and any vacuum operated controls like those in older cars eg climate control systems, vacuum locks, etc.
Re: Vacuum pumps [Re: supton] #5432286 05/18/20 11:25 AM
bdcardinal Online Content
Online Content
The dry sump tank which has a separator.
1995 Ford Mustang GT
2003 Chevy Silverado 2500
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Vacuum pumps [Re: Local Color] #5432319 05/18/20 12:15 PM
SpitFire6 Online Content
Online Content
Hi,
No idea what engine you have. On a "classic" engine a slight depression on the internal of a wet sump engine is a good thing as long as no liquid ingested.
It would have to be a large volume pump to exceed what is available from inlet manifold though.
Cheers,
Iain.
2002 206 CC 2L 4Cyl. 0W40 FS
1972 Spit 2L5 6Cyl. 0W40 FS
Re: Vacuum pumps [Re: Local Color] #5432328 05/18/20 12:23 PM
L
L
Thanks to all the answers
Re: Vacuum pumps [Re: Local Color] #5432344 05/18/20 12:38 PM
R
racin4ds Offline
R
If your car is new(er) or even decades old, it will have a PCV system which pulls a vacuum on the crankcase from the intake manifold at any time other than WOT anyway.
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Re: Vacuum pumps [Re: Local Color] #5432748 05/18/20 07:19 PM
M
Mitch Alsup Offline
M
It is done all the time in engines with dry sump systems.
The oil scavenges pumps (plural) pull more oil out of the sump than the oil pressure pump can push into the engine.
There is a partial vacuum in the block, which also means they typically do not need a PCV valve and simply vent the gas off the deaerator in the dry sump into the intakes.
My Ferrari F355 has such a system.
