Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
Shopping for New Generator
by doolah02 - 06/01/20 12:02 PM
Horsepower in Various Modes
by Al - 06/01/20 11:39 AM
ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
Used Mitsubishi Lancer prices
by 97prizm - 06/01/20 10:32 AM
Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
88 registered members (Alfred_B, 16HC, 6x6man, AndyB, 330indy, 2004tdigls, 12 invisible), 2,309 guests, and 22 spiders.
Topics306,126
Posts5,286,930
Members71,588
Oil type and bubbles #5387024 03/27/20 01:02 PM
O
OliverQ50 Offline OP
O
I have been a loyal customer of Pennzoil after reading all the posts here. But recently I realized that PUP 0W-20 is not the right oil for my VR30 since it is a TGDI. So I decided to switch to Mobil 1 EP 0W-20 as it was on sale.
The engine sounds a bit louder with the Mobil1 EP, but I am quite surprise that there is no bubbles on the dipstick at all when I check it immediately after the engine shuts off. But with PUP, there would be many tiny bubbles, although they are gone if I check 15 min later. Does this mean that Mobil1 has better antifoam additive than PUP? Would those bubbles in PUP do any damage to the engine?
This is not related to overfilling since I always adjust the oil to the same level. And I am sure that the oil temperature is in the same range.
Re: Oil type and bubbles [Re: OliverQ50] #5387063 03/27/20 02:01 PM
T
Triple_Se7en Offline
T
I was taught in 1969 that the best way to check your oil dipstick level - is after the engine sits overnight. No Lawrence Welk Bubbles.
2019 Hyundai Santa Fe 2.4 GDI - Pennzoil Ultra Platinum 5w30 / OEM 35504 Filter
2020 Kia Soul X-Line 2.0 MPI - a 50-50 blend of Pennzoil Platinum HM & Pennzoil Gold 5w30 // AC Delco PF1127 Ecore
Re: Oil type and bubbles [Re: OliverQ50] #5387070 03/27/20 02:19 PM
W
wbwanzer Offline
W
Re: Oil type and bubbles [Re: Triple_Se7en] #5387108 03/27/20 02:46 PM
B
BAJA_05 Offline
B
Agree 110% wink
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: Oil type and bubbles [Re: Triple_Se7en] #5387118 03/27/20 02:58 PM
O
O
But you won't find out whether the oil has foaming issue if you check it overnight.
Re: Oil type and bubbles [Re: OliverQ50] #5387143 03/27/20 03:36 PM
csandste Offline
https://www.machinerylubrication.com/Read/255/oil-foam
Here's an article that describes foaming causes albeit for heavy machinery. My take on this is not to worry about the few small bubbles you found with Pennzoil. I've had about forty cars in my life and I'm sure I've seen a bubble or two on the dipstick, and I'm sure it wasn't from crankcase churning.
I've never used PUP. Why is it unsuitable for TGDI?
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Oil type and bubbles [Re: OliverQ50] #5387276 03/27/20 07:07 PM
O
OilUzer Offline
O
op,
While you are at it, do some research on viscosity grade as well ... iirc, with TDGI, higher viscosity oil plus dexos may work better. Not suggesting that you shouldn't follow your manufacturer recommendation ... but use that search function and decide.
Btw, we have a 4 cyl 2.4L gdi and never seen any bubbles using PP and/or M1 EP and even different dinos. However the lowest viscosity I have used is 5W30 and the engine runs very cool. It's not a turbo but it runs much cooler maybe because of 5.x quarts. Yours is most likely running much hotter. I have a 2.7L mpfi v6 with 4.2 quarts and runs hotter.
Re: Oil type and bubbles [Re: OliverQ50] #5387314 03/27/20 07:42 PM
O
Oildudeny Offline
O
i miss wolfs head conventional
Re: Oil type and bubbles [Re: OliverQ50] #5387320 03/27/20 07:48 PM
E
Eddie Offline
E
From a cold start My engine revs to ~ 1400 and drops to 1,000 in under 10 seconds and then I go gently. Ed
2014 CX5 Touring 2.5L :-)
Re: Oil type and bubbles [Re: OliverQ50] #5387427 03/27/20 09:36 PM
O
OilUzer Offline
O
According to the link @csandste had posted, not letting oil to warm-up can cause foaming.
I knew running fast quickly is not a good idea but had forgotten about some of the reasons ... like foaming.
Re: Oil type and bubbles [Re: OliverQ50] #5387484 03/27/20 11:05 PM
P
painfx Offline
P
There are articles that states to not let the engine warm up because of fuel economy reasons. I just warm up 2-3 minutes and drive slowly. Just personal preference.
