jfrankh
Thread starter
Originally Posted by ARCOgraphite
Originally Posted by TiGeo
Originally Posted by kschachn
Use an oil that has the actual approval required for your vehicle and ignore grade as it is irrelevant.
Also don't troll the board.
What about his post is trolling?
Looking for oil for a VW ( normal) then immediately saying I'm going to use LUCAS 0W30 (very esoteric).
I'm sure the oil will work fine, Lucas motorsport products are well formulated, it's their big box automotive "additives" that are garbage.
I guess you got to sell a lot of junk to make the good stuff.
No VW approval, but I'm sure the oil will work fine if it has correct min HTHS.
Why would it NOT? Are these VW gas engines ticking time bombs that will explode on a whiff of "Mercun" oil?
If so, they are junk.
The Op will have to assume that risk if the engine has a warranty issue that is lubricant related.
I think he has been schooled on that.
Esoteric? How was I intending anything I said to be understood only by a chosen few? I was saying that I was going to use oil "X" before I stumbled down this rabbit hole. Not that I am going to use oil "X" regardless of the advice I receive here? I have received a lot of helpful advice in the replys. Tough crowd.
