Originally Posted by Mainia
Mobil1 5w-30 ESP.
And you "dump" it at 3k?
As Triple_Se7en stated, Hyundai's abuse of oil is correct. In Minnesota winters, short hwy on ramp 1/8th mile away from home that you need to get up to speed ASAP, and 17lbs boost at 1,450 rpm, I need to somewhat pre warm my car up every morning for 4 mins before going to work. Well over 5% fuel dilution which now is a "yawn" after seeing no wear through UOA. And thrashing the motor with being on boost more then most, it is the cost of doing business in a car that is in "Sport Mode" most of its life.
I would be looking for a cheaper oil like SuperTech, etc.
