Coil packs are not maintenance items. If it's not broke, don't fix it.
Anduril said:I replace them all when one starts to misfire as the others can't be far behind. OEM parts only, no eBay specials.
Good advice here. Replaced just the failed one only to have the rest to replace shortly thereafter. If your planning to sale/trade it's a quick fix but only then is replacing one a good move.
Yes, Toyota Sienna 3.5, you really have to be prepared to get that 1 intake plenum bolt, and the intake plenum has hex head bolts holding it down. Then the wiring harness has to have a couple of hold downs that have to be removed as I recall it is strapped tight against the rear valve cover and has to be wrestled out of the way for #5 especially.Originally Posted by RDY4WAR
Agree here with the exception of hard to reach rear banks in a transverse V6.
If you have to remove the manifold to replace the spark plugs, it might be worth it to the shade tree mechanic to change out COP's with OEM only. This assumes you don't want to go back in to that rear bank in the future.
Denso's run about $50ish each for my '03 Camry V6 on RA. I'd likely shell out $150 for the feel good feeling of knowing I don't have to pull that manifold off ever again.
in my experience simply removing a coil pack that has been in place for 100k+ miles can cause a latent failure that takes down the coil some time later... eg mechanical stress of removal causes old/weak rubber or plastic to fracture letting in moisture, and then a year later you get a misfire. the late 90s Nissan coils were notorious for this (mitsubishi made as I recall).
so unless you enjoy pulling off your intake just put new coils in while you're at it. now up through '99 the Nissan VQ30 intake was designed so you could remove the back bank coils without removing the intake.. very nice! then they mucked it all up starting in 2000.
