Originally Posted by Deliverance95345
Originally Posted by MolaKule
Originally Posted by mctmatt
Hy-Per Lube also has another additive called Oil Treatment that you can add in place of a quart of oil when you change it. Does this additive provide any real benefit as the above product for a daily driver as I have a 96 Ford Taurus that runs great, and I use it to and from work 12 miles one way with half being at least in stop and go traffic here in Austin TX. I change every 5,000 miles as it is easy to keep up with those intervals.
No, that product is solely an oil thickener, is only good for smokers, and has no place in well maintained engine that has used modern oils.
I just used this on my truck tonight, 1QT Hyper Lube to 6QTS Castrol Edge.
Will it mess up my truck? Should I drain it the minute I get to work later today?
Truck has 103K miles, no oil leaks or burning/usage. Very well maintained but did add to try and quiet a small tick I had been hearing
Truck used BG MOA multiple times in the past without issue.
Thank you
I don't know if it's necessary to drain it immediately but I'd probably change it out sooner to put just oil in, or oil and the better hyper lube stuff from the original post. Maybe an early change will help the tick anyway.
