Dry Gas in exteme cold weather
by FA_WRX - 01/17/20 06:57 AM
ATF VS ATL
by jrommelt - 01/16/20 11:24 PM
inline oiler for water separator on compressor
by motor_oil_madman - 01/16/20 10:55 PM
5w30 Throw Off VVT [ 5w20 Vehicle ] ?
by Fallguy - 01/16/20 10:54 PM
Ravenol MTF-2
by E365 - 01/16/20 10:36 PM
Road Rage, Then vs Now
by gathermewool - 01/16/20 09:39 PM
Interesting Taillight Out Code
by Gebo - 01/16/20 09:39 PM
Well its here again
by JohnnyJohnson - 01/16/20 06:56 PM
My cheap old stock oil score!
by CleverUserName - 01/16/20 06:52 PM
Trans runs better in severe cold...
by 2009Caraman - 01/16/20 06:41 PM
LSx rocker bolt sealant
by P10crew - 01/16/20 06:00 PM
Nissan Titan any good?
by dfarr67 - 01/16/20 05:24 PM
Cockford-Ollie
by 1978elcamino - 01/16/20 05:23 PM
ATI balancer keyway sealing
by P10crew - 01/16/20 04:53 PM
Silkolene (FUCHS) 10w-60 On Amazon
by BBDartCA - 01/16/20 04:19 PM
To use or not to use
by JHogan - 01/16/20 04:13 PM
The Motul Oil Line...
by Navi - 01/16/20 03:38 PM
Help identifying this drill bit
by henni - 01/16/20 03:13 PM
P38 Lightning
by Kamele0N - 01/16/20 03:01 PM
Why does oil in the spark plug hole cause misfires?
by berniedd - 01/16/20 02:27 PM
MrGoodwrench, Schwifty, Karoofrans, Marksvc1, Anthony_Butcher
70452 Registered Users
70 registered members (AndyB, 2015_PSD, adams355, alchargo, alarmguy, 4WD, 3 invisible), 1,479 guests, and 15 spiders.
Topics300,215
Posts5,171,082
Members70,452
Most Online3,728
Jan 11th, 2020
Page 1 of 4 1 2 3 4
Ate up camshaft.pics #5294391 12/14/19 02:57 PM
Chris142 Offline OP
We had this engine rebuilt locally. Installed it in a 1986 Toyota pickup. I personally put the bottle of cam break in lube in it. We ran it @2000 rpm for 30 minutes
We let the customer drive it a week. After a week we changed the oil and filter. I also adjusted the valves at this time.
The customer is very good about oil changes and he uses Chevron delo 15w-40 in it.
Now 2 years and 30000 miles later he brings it in because it's not running right. Here is what we found.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Ate up camshaft.pics [Re: Chris142] #5294396 12/14/19 03:03 PM
O
OVERKILL Online Content
Online Content
O
Aftermarket premium Chinese camshaft? crzy
Re: Ate up camshaft.pics [Re: Chris142] #5294405 12/14/19 03:13 PM
K
Kruse Online Content
Online Content
K
Okay, I realize that you're in California and it's always warm there. I got it.
But why is that engine getting a steady diet of 15W-40?
Re: Ate up camshaft.pics [Re: Chris142] #5294418 12/14/19 03:28 PM
spasm3 Online Happy
Online Happy
Wow! Have to wonder what brand cam that is!
I think i would put new lifters, and valve springs when you replace this cam.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Ate up camshaft.pics [Re: Chris142] #5294420 12/14/19 03:32 PM
T
terry274 Offline
T
All the parts in those pictures look really dry, as if oil never made it to the top end. What am I missing?
2011 Toyota Avalon
2019 Honda Ridgeline
2009 Ford Taurus
2012 Honda Accord
1996 Ford F150
Re: Ate up camshaft.pics [Re: terry274] #5294422 12/14/19 03:35 PM
spasm3 Online Happy
Online Happy
You are right, i don't see oil anywhere!
Re: Ate up camshaft.pics [Re: Chris142] #5294423 12/14/19 03:40 PM
PimTac Offline
One has to wonder what a UOA might have revealed during this?
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Ate up camshaft.pics [Re: OVERKILL] #5294427 12/14/19 03:42 PM
demarpaint Offline
It sure looks like the top end of the engine is starving for oil.
God Bless Our Troops
Re: Ate up camshaft.pics [Re: Chris142] #5294443 12/14/19 03:58 PM
danez_yoda Offline
MAN all the wore down cam lobe metal running through the engine. I'm assuming there was oil up there since I don't see a pile of metal filings stacked up. Did you clean area with break cleaner and vacuum out the resisue before taking the picture?
Why would a 86 pickup need a new cam shaft unless it has over 500K miles. That was the famous 22R engine that ran FOREVER. smile My dad put 400K miles on his and parked it still running when a lawn company saw it and bought it from him.
Re: Ate up camshaft.pics [Re: spasm3] #5294457 12/14/19 04:20 PM
Chris142 Offline OP
that's after a trip to the solvent tank.
Re: Ate up camshaft.pics [Re: Kruse] #5294460 12/14/19 04:22 PM
Chris142 Offline OP
I don't know why he chose that oil. Update: that's what the rebuilder wanted.
Re: Ate up camshaft.pics [Re: spasm3] #5294462 12/14/19 04:23 PM
Chris142 Offline OP
ya it took out the followers too.
Re: Ate up camshaft.pics [Re: Chris142] #5294464 12/14/19 04:25 PM
G
GoldDot40 Offline
G
I'm guessing there was a failure in the rocker arm or the shaft assembly. Maybe some sort of alignment/geometry issue. Could be a QC issue on aftermarket parts as well.
Equal Opportunity Offender
Re: Ate up camshaft.pics [Re: Chris142] #5294465 12/14/19 04:25 PM
J
JC1 Offline
J
Chris,
How much oil was in the sump? Perhaps it was running low on oil.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Ate up camshaft.pics [Re: spasm3] #5294468 12/14/19 04:27 PM
G
GoldDot40 Offline
G
22r is an SOHC engine that doesn't use lifters. Rocker arms ride directly on the cam lobes.
Page 1 of 4 1 2 3 4
