I've put about 70k miles on my 1983 305 Chevy which were known for eating the original camshafts back in the day. I've heard it was just the original camshafts which had the problem, but I don't know that for sure. I do suspect it probably had the camshaft replaced early on because I can see orange rtv sealant around the intake manifold (cast iron intake on fast iron heads - they almost never leak as far as I know), but I don't have all the original repair history.
I did used to use zinc additive for the first several years I had the car but I think I stopped bothering about 5 years ago. So far, no issues. The engine sounds the same as it did 10 years and 70k ago. We'll see if anything bad happens in the next couple of years. I've used everything from 0w30 synthetic to 10w40 or 5w50 synthetic. Currently 0w40 Mobil 1.
At this point if it fails I'll just have to hurry up on my 5.3 ls swap. The 305 is at 235k miles now.
I'm still trying to watch any current discussions about zddp and non roller valve trains because my other car is also flat tappet and I stopped using zinc in it also. It's a 76 350 Olds which were never known for cam problems. It's got well worn factory valve springs and very low lift so it's not likely to be an issue. Also several years and quite a few miles of over the counter synthetics of various grades. I settled on 10w30 because the engine is quietest on it and it's a summer only car.
Sorry if this is off topic now because the op issue is probably a parts quality issue but oil and zinc was brought up, and I still wonder whether I made the right choice in leaving out zinc additives. Best option would be a higher zinc boutique oil like amsoil or redline and I have used them before but I realized they aren't in my budget when I can pay half price $28 for 5qts of Mobil 1 or Pennzoil Platinum, etc and they "seem" to work fine in my engines.
